Hello, I have apparently had another problem with my problematic machine.
Everything worked well and suddenly the machine began to complain about the Infuser.
Thereafter, all the water from the rinse cycle is passed directly to the drip tray.
Even the brewed coffee is poured directly into the drip tray. This machine has been working well all the time, it seems to be exactly the same as another machine.
If you point the infuser to the upper limit switch during the load test, the message GENERAL ALARM will be displayed
----------------------------English
Hi,
I am having trouble with my problematic machine.
Everything was working fine, and suddenly the machine started complaining about the infuser.
The water from the rinse cycle goes directly to the drip tray.
Even the coffee that gets brewed goes directly to the drip tray.
This machine was working the whole time, it seems to be having the same problem as another machine.
Homing the infuser in power load menu gives a GENERAL ALARM message when the infuser reaches the top limit switch.
