REOPEN SOLVED esam 3000 not job, alarm generic only, please help!!!
  • cmcshm schrieb:
    alarm led is fixed now push on, coffe 1 and 2 freshing,
    open close port, alarme off and purg flashing,
    after secunds test automatic, and alarm fixed, but infuser up down perfect...
    make a small movie with your handy cam and load it up to youtube.
  • This video is private
  • Was the heater hot at this time you pushed the on button?
  • Maybe there is a problem with the reed circuit board. Check the grey three-wire cable. You can see it in your movie at 1.44
    no undestand, water its hot, but in test not big hot...
    please send picture to reed board or indicate, im not look...thanks
  • I marked it in the picture
      491,23 kB, 1.296×2.304, 150 mal angesehen
  • cmcshm schrieb:
    ohms???
    Yes(beep curtciruit), you have to check if one of these 3 cable sometimes its brocken sometime its okay.
  • ok im look
    pins:
    3
    1 to 2 = 10kohm
    1 to 3 = 500ohms
    2 to 3 = 10kohms
    other cable
    blue
    blue
    red
    blue - blue = bip
    blue to red = 1,5kohms
    add in your pdf!!!
    please Best explain THAT plate , where it goes and How This circuit
    know where to find electronic scheme of this machine?
    I am increasingly convinced that the problem is the motherboard ...
    please other dude: mod test whats push on led fixed 2 coffe, push on fixed led red tray down, ??? im not understand all test,
    whats procedure to vaper in test mod? im only hot water
    Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von cmcshm ()
  • You have a conversation.
  • No support at the chat. At the left top of the screen you have softkeys with your name, Benachrichtigungen and Konversation. At Konversation is a 1, that means you have one message.
  • please values tested its ok???
    im need reser encoder, but whats procedure???
    cmcshm schrieb:
    ok im look
    pins:
    3
    1 to 2 = 10kohm
    1 to 3 = 500ohms
    2 to 3 = 10kohms
    other cable
    blue
    blue
    red
    blue - blue = bip
    add in your pdf!!!
  • Forget your measurement, they say nothing. Down in the picture, you see the reed circuit board with the plug. you have to messure from one yellow arrow to the other yellow arrow, then from red to red and from blue to blue. During you messure you have to move the cable maybe somewhere it is broken. You find the reed circuit board as you open the machine bottom.
      451,84 kB, 2.304×1.296, 167 mal angesehen
  • im look in net reset encoder or only reset, no understand, you explanish please, its possible:
    purgue + eco + on machine mecanical button
    machine its 100% working now
    problem only software or memory...
    please send modes test/reset and others...but not look in manual user or service, nothing info...
    im identify
    mod test:
    1 coffe+ vaper + on machine mecanical button
    and reset, SOLVED MY PROBLEM...
    exinting others modes or resets???
    in Brasil tecnics followme to change board... condenate machine, but price board over 200usd...
  • Sorry, but i unterstand nothing.
    Versteht das irgendwer?
  • Ja, er meint, dass die dortigen Techniker ihm gesagt hätten, dass die Leistungsplatine hinüber ist und sie 200 Dollar kosten soll.
    Aber genau das ist tatsächlich der Fehler. Hatte auch eine 3000 EX1 hier mit demselben Fehler. Maschine war nur zu betreiben, in dem man nach Start die Klappe öffnete und wieder schloss.
    Der Kunde hat dann lieber den kleinen Umstand in Kauf genommen als die Leistungsplatine wechseln zu lassen. Verständlich.
    @cmcshm:
    You got to change the board. Or you handle the problem like shown in the youtube-video you posted.
  • oi Stefan
    MELHOR DO PROBLEMA RESOLVIDO !!!
    reiniciar a placa:
    energia fora
    de imprensa Purg + eco botões
    em energia
    de imprensa na
    imprensa PURG
    imprensa sobre
    energia para fora
    outra conexão problema-look T - número 35 próximo diagrama, sua compressão fora oring
    de diâmetro necessidade orgin T (35) e 92 diagrama, para comprar no Brasil, mas a Alemanha muito expansivo enviar para o meu ...
